porting not complete
Asif_Kachra
I Just moved two lines to Public Mobile, and had problems to complete my full subscription because I never received the Code authentication texted to me by Public Mobile for Authentication
Asif_Kachra
there is no option to speak to someone to confirm porting
Asif_Kachra
yes old sim is still active but only for outgoing calls
Sansan
Is your old sim card still active? Did you reply to the text to confirm if it was completed successfully? I will send you another message with the number to call to verify status.
HALIMACS
@Asif_Kachra
  1. Use the ticketing system for a faster response time. Click here and type Customer Support Agent, then select Contact Us, then select Other (or the topic that more closely matches your request).  Click the result which states Click here to submit a ticket and follow the prompts,  or,
  2. Send a private message to the Customer Support Agent by clicking here  You’ll need to be logged into your Community account for the link to work.
