porting failed
brianreimer
My number porting failed. I was told by Public Mobile that I need to provide my previous account number.  How do I provide my previous account number so that Public Mobile can restart the process?
Thanks Brian
2 REPLIES 2
gblackma
@brianreimer contact the moderators and ask them to port it for you.  Type " Port Request " and follow the prompts to get to one. Give them the name on the account, the number to port and the previous providers account number.  Note the previous providers account must be active to port your number.  The port will close it once its completed. There are 2 ways to contact the Moderator Team:
  • Faster response- Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to the Moderator Team. Click here to get started.
  • Slower- Alternatively, you can send a private message to the Moderators by clicking here. You’ll need to be logged in to your Community account for the link to work.
Once connected to Simon, you will be asked to log in again with your community user name and password.  Please do, this allows you to continue and send your message.
- Keep an eye on the envelope top right of your screen.  The mods answer will show up there.  When it does, you will be asked to verify your self service account, with your password and login. Doing so allows the process to continue. Stay safe.
RossN
Thanks Brian
@brianreimer contact a moderator  click on the ? Bottom right hand corner Ask Simon to speak to a human this will help create a ticket to speak to a moderator  mention port failure     check the envelope top right corner for a reply response time is 2 to 48 hours
