ported away. NOw can't sign in account to disable billling
blue99subaru
it seems access to my account, which is paid up til July 7 has been disabled.
How can i access my account on line to disable bililng???
9 REPLIES 9
What plan/carrier did you end up going with?
Next time you may want to remove autopay and your cc before porting out just in case. Once in awhile ppl have reported getting charged even after porting out (although rare) So keep your eye out
blue99subaru
TY all.
blue99subaru
good point to consider billing cycle when port out. ...i decided to port  when plan ran out of data yesterday.  In hindsight, surprised i stayed so long with public mobile... ( $120 / 12 gb / 3 months) is by no mean a good deal using a 3G ntwk. and $15 for adl GB whenever i run out.....Nowadays
many carriers offer $50 / 10gb / monthly
@blue99subaru- Once your port is completed, your account is closed, and your SIM is dead.  You cannot keep using it until the end of the billing cycle.  That's why it is recommended to consider your cycle dates when planning to port (in OR out).
@blue99subaru wrote:
thank you  Mr. Spock. Appreciate ur quick response.   I was wondering about the billing aspect.  On  a separate nute...   Since i have paid til July 7, i should still be able to making outgoing call... dont u think
By porting out, the rest of the Public Mobile plan duration has been forfeited.
MrSpock
@blue99subaru no unfortunately like I mentioned your account is closed and your service is terminated also
blue99subaru
MrSpock
@blue99subaru hi once you port number your account is closed permanently you will not be billed any further
will13am
