port in query
09-03-2019 03:41 PM - edited 01-05-2022 06:50 AM
I have ported in my number on the time of the sim card activation, When I put the sim on the phone and tried to call to another line, the number appears to be the ported number however the number that I have ported in is still active on the old provider instead of dead line, how is that possible? this means my number is active on both provider, where it should have been automatically cancelled on the other provider. should I receive a notification that the number is successfully transfered? thanks in advance!
Joining Public
09-03-2019 04:42 PM
@chinkymae24 wrote:I have ported in my number on the time of the sim card activation, When I put the sim on the phone and tried to call to another line, the number appears to be the ported number however the number that I have ported in is still active on the old provider instead of dead line, how is that possible? this means my number is active on both provider, where it should have been automatically cancelled on the other provider. should I receive a notification that the number is successfully transfered? thanks in advance!
@chinkymae24 Just continue to use your old sim once it stops working then it means the port is 100% complete and then just insert your PM sim and everything should work.
09-03-2019 03:46 PM
Okay, thank you for the fast response
09-03-2019 03:45 PM
@chinkymae24 it means your port is in the process, when it's complete you'll get a text saying it's complete and your old Sim won't work anymore
