07-05-2022 11:54 AM
Hello. If I upgrade my plan to the 25 dollar plan from the 15 dollar plan, will it take into account that I have already paid my monthly fee of 15 dollars or will it want the whole 25 dollars. Thank you.
07-05-2022 12:11 PM
It's highly recommended to manually pre-pay the new plan cost before the renewal/plan change. There's a long-standing system bug where autopay fails on a upward plan change leaving you with suspended service.
07-05-2022 12:08 PM
It'll be here before you know it 😉
07-05-2022 12:04 PM
Thanks for the help. I will wait till the end of July since that is the renewal date.
07-05-2022 12:03 PM
@swerve, if you absolutely need to switch now to the $25 plan it will take the full amount. There is no pro-rating of plans on Pre-paid services. If you can wait the best option is to go and schedule the plan change to happen on your next renewal date.
07-05-2022 11:56 AM
It would be the entire amount, there is no prorated here. How close are you to your renewal date? You can either change on next renewal if you can get by until then and it will upgrade to the $25 plan at that point, if you choose immediate change the full 25 will be charged and the 30 days will start then.
07-05-2022 11:56 AM - edited 07-05-2022 12:03 PM
@swerve Hi if you change the plan early you will loose what is left on the $15 that you paid it is best to renew at your next payment date
