phone problems
TootsieRoll
My friend is away and I need help with my phone.
Civic_E
@amritveerbnext step is to send a private message to Public mobile Moderator @CS_Agent and ask them to request the port again now that your chatr account is active.
amritveerb
i had a CHATR account and ported my number to PM, but turned out that my chatr number was not active at the moment, but the number had been on PM it is making calls but not recieving, i have paid my chatr to make it active, what is the next step i take?
TootsieRoll
Thanks for replying. I'm just learning how to use the system.
mimmo
@TootsieRoll  can you be more specific with your isssue.
To start what phone are you using and what is the specific issue you are facing.
