03-22-2019 02:06 PM - edited 01-05-2022 06:57 AM
03-22-2019 02:39 PM - edited 03-22-2019 02:40 PM
@upthestump wrote:
- my original plan was 8gb data4 at 3G unlimited calling usa and unlimited text i want this reinstated immediately!!! some 0ne get back to me via email thanks D.
- current plan
- This plan includes: -
- - 2GB + 500MB BONUS at 3G Speed
- - Unlimited International Text
- - Unlimited Talk to Canada and the US
@upthestumpif you did not change then you should
send a message to the @moderator_team by clicking on the following link:
The link sends you to the private message function and adds the moderator team as recipient for a private message. You just have to enter a title and text in the body of the message describing the problem and post. The message will be received by the moderator team and they will respond to it. You will receive the response in your private message inbox.
03-22-2019 02:29 PM
@TheGx wrote:Have you private messaged the moderator team about this yet? Here is their link:
Moderator team are only ones that could help you with system or plan problems.
That depends on the problem which is unclear at this point. Recommending to send a pm to mod without knowing the issue, users will send a pm to mod anyways and more time from mod is taken regardless if this was actually an user error or system error.
03-22-2019 02:25 PM
@upthestump To make these change
I suggest you to please send Private Message to Moderator by CLICK HERE
*** Please note: I am not a Moderator ***
03-22-2019 02:22 PM
03-22-2019 02:19 PM
- current plan
@upthestump, as @NDesai has asked, please let us know whether you changed your plan or the system did. We need details on your situation, so we can help you figure it out We're customers like you.
03-22-2019 02:14 PM
- current plan
@upthestump You can download some free calling apps for call within North America. I use TextNow and Fongo (don't cover certain areas in Canada). They are quite good. But you need wifi or data to make call or text. No limit of minutes at all.
Seems PM changed the plan to fit locally. You may not be able to get what you want.
03-22-2019 02:10 PM
@upthestump Some confusion here. DId you change your plan from 8GB to 2.5 GB one? Or are you saying that system changed it itself?
