phone issue
07-06-2019 09:40 PM - edited 01-05-2022 05:45 AM
07-07-2019 02:59 AM - edited 07-07-2019 03:02 AM
@Dogbert wrote:Anychance you accidentally put your phone into do not disturb/airplane mode?
Asked almost 5 hours before you by RossN. Third time repeated. No need to repeat again. Does repeating earn reward?
07-07-2019 02:38 AM
07-07-2019 12:49 AM
@mimmooh, I overlooked... Thanks for reminding!
07-07-2019 12:30 AM
@sunflowershine the poster said the had used 27 minutes about an hour before you posted 2 posts above yours.
07-07-2019 12:07 AM
@kush816 $10 plan is 50 minutes (incoming & outgoing) and unlimited incoming texts and 50 outgoing texts. When retrieving voicemails, it counts the minutes too. All calls round up to next minutes (1:30 min = 2 min will be deducted).
You may check out your usage under My Account.
07-06-2019 11:17 PM
OK so minutes left in plan.
Did you try any of the other suggestions? If so which ones?
Please try pm sim in a differnt phone.
Do your other features work incoming sms? Out going calls?
07-06-2019 11:08 PM
27min
07-06-2019 11:07 PM
@kush816 wrote:i have that $10 plan.. incoming call free and 50 txt.. no outgoing calls.. anothe qestion that i have is how you set up voicemail..
@kush816 incoming calls are included only with the $15 plan but not the $10 plan. You must have rin out of minutes. To fix just purchase the $5 509 minute addon.
07-06-2019 11:03 PM
@kush816 incoming calls on the 10$ plan use up minutes.
Can you log into selfserve and say how many minutes are used or if the 50 min talk is still showing?
What do you mean no outgoing calls?
07-06-2019 11:02 PM - edited 07-06-2019 11:03 PM
@kush816 you also mentioned incoming calls free I don’t believe they are on the 10 dollar plan
07-06-2019 10:59 PM
@kush816 @hi remember you use your minutes setting up voicemail on your phone
07-06-2019 10:50 PM - edited 07-06-2019 10:51 PM
07-06-2019 10:38 PM
07-06-2019 10:28 PM
@kush816what plan are you on? is everything else working data sms, outgoing calls?
do you have the same issues when you put the pm sim in your other phone ? (you mentioned putting a different sim in your phone, but not viceversa)
this is not likley but could you have enabled call forwarding accedently?
if someone calls you twice right away what happens?
07-06-2019 10:10 PM
let me try that
07-06-2019 10:09 PM
Only other thing I could find, shut down phone. Reseat sim and turn back on. But you probably did that. Message to @CS_Agent is likely necessary.
07-06-2019 10:08 PM
@kush816 wrote:everything on phone is fine.. i put another sim card and its ringing
@kush816 Sometimes doing a soft reset using the lost/stolen phone trick will clear up account issues. To report your phone stolen. Login to your selfserve account. Choose Plans and Add-ons tab. Choose the Lost/Stolen Phone tab. Choose Suspend Service tab. Wait a few minutes. Report your phone found. Re-start you phone
07-06-2019 10:02 PM
07-06-2019 09:58 PM
@kush816 wrote:it was bell they already call me yesterday.. we talk everything was fine.. i mean once i got the text saying that your number is ported i start using and it was fine.. i was using public mobile yesterday and it was working fine... its not like i just switch and expect to work right away.
@kush816 Check to make sure your phone's do not disturb mode is not turned on.
07-06-2019 09:56 PM
and the old sim is not working because theres no service
07-06-2019 09:56 PM
07-06-2019 09:55 PM
@kush816 Could you try switching from LTE to 3G network.
07-06-2019 09:54 PM
07-06-2019 09:52 PM
Try cycling your airplane mode.
07-06-2019 09:51 PM
Check the phone settings in case you have accidentally turned on block calls, or do not disturb. Those are usually the culprits.
Then login to voicemail confirm that is also not set to send to voicemail.
07-06-2019 09:50 PM
its already transfere...
07-06-2019 09:49 PM - edited 07-06-2019 09:50 PM
07-06-2019 09:49 PM
@kush816 wrote:yeah.. and i cant even go thru my voicemail
@kush816Who was your previous provider? A phone port is not immediate your old provider must release you number before you can start receiving calls. Best to continue to use your old sim card until it stops working. Once that happens it means that the port has completed and at that point if you insert your PM sim card you will be able to receive calls.
07-06-2019 09:48 PM - edited 07-06-2019 09:51 PM
Use your old sim until porting process is completed. You'll recieve a text from PM when that's done.
07-06-2019 09:48 PM
yeah.. it was working fine yesterday but today is different,, its going straigh to my voicemail
