07-31-2019 02:55 PM - edited 01-05-2022 06:12 AM
08-02-2019 09:27 PM
See Public Mobile does have a heart and they are reasonable. Enjoy your savings now, hopefully long into the future!
@zhuanglm wrote:finally, Mod asked me to buy a new sim card , and they helped me to changed the sim num on backend, and I got the money back as credit in my account.
08-02-2019 09:19 PM
I'd like to mention that they asked me to buy new sim card starts with 891223.....
08-02-2019 08:58 PM
Mines been like that for a month. I'll reach out to the mods too see if it is a SIM for me too. I guess it has been transfered a few times, (but mostly to try to fix this issue!)
08-02-2019 08:44 PM
08-01-2019 02:09 PM
yes, voice mail.
08-01-2019 01:39 PM
@zhuanglm Waht happens when you dial your number from another phone. Does it go to VM?
08-01-2019 01:28 PM
08-01-2019 10:30 AM
@zhuanglmthis tread has asked for screenshots multiple times now. If you wish more assistance that we should be able to provide, please post the screenshots.
08-01-2019 09:58 AM - edited 08-01-2019 10:06 AM
@zhuanglmJust want to make sure you didn't get SIM jacked. But if you can log into your selfserve then it should be okay.
08-01-2019 09:48 AM
I have never changed my card , and so my card seems no problem, cuz all of phones could identified the number and carrier of the SIM
07-31-2019 07:23 PM
@zhuanglmCan you log into your selfserve account and double check if the last 4 digit of the SIM card matches that on that is in your file?
HOW TO CHANGE YOUR SIM CARD #
07-31-2019 07:20 PM
update: I tried use public mobile SIM in both samsung galaxy4 and google nexus 5 . doesn't work, devices could read phone number from card but could not register into network. all of those devices could use other SIM cards.
07-31-2019 05:14 PM
That is interesting that you were able to activate service on an older device (Nexuus5). With your current problem, are you able to enter the "SIM" on the "Activate Sim" page; or does it say "Invalid SIM" when you attempt to enter "SIM Card details"?
If you do see "Invalid SIM" it likely means that the SIM has been registered to an account already; and the port failed.
07-31-2019 03:23 PM
thanks
07-31-2019 03:22 PM
no, I didn't make any change recently.
07-31-2019 03:14 PM
Are you starting a new plan, or changing your phone number? A port is changing a number by bringing it from a different carrier.
If you're just turning on the phone, I assume you're already a customer, and it's possibly a network issue or service outage that is affecting you.
You must invoke a port via Self-Serve, and if you haven't either your account has been compromised, or some other fishy thing has happened.
The account could be expired, suspended, something else. We need more or better information to know what's going on.
07-31-2019 03:08 PM
@zhuanglm wrote:it has happended before. I tried to set SIM in my MI mix2 and iphone6, both of them can not log into service. after I inserted it into Nexus5, it worked. and then put it into mix2 again, could connected. this time I didn't tried this way, because I checked through this issues and found out similar issure :https://productioncommunity.publicmobile.ca/t5/Getting-Started/Phone-showin-quot-No-service-quot/m-p.... it is port problem, so I think if my issue is the same thing?
@zhuanglm Best to contact the Moderator Team and aske them to check it from their end.
To contact Public Mobile click here. The link sends you to the private message function and adds the moderator team as recipient for a private message. You just have to enter a title and text in the body of the message describing the problem and post. The message will be received by the moderator team and they will respond to it. You will receive the response in your private message inbox.
Moderators are available: M-F from 8 AM to midnight Eastern time and S-S from 8 AM to 10 PM Eastern time.
Note: Moderator Hours are subject to change, but you can always find the current times here
07-31-2019 03:02 PM
07-31-2019 02:56 PM
