phone can't call out
soph
Hi,
I can't seem to make any calls from my phone.  I can't receive them though.  I had my son test out his phone cans he can't make calls out either.
Every time I try I get a msg indicating I can't make that call because I don't have a long distance plan.  My son gets the same msg.
Is this a Public Mobile wide issue, as my son and I have seperate accounts??
pls help, thanks,
Soph
10 REPLIES 10
srlawren
@Glennb2018 sounds like it's resolved:  https://productioncommunity.publicmobile.ca/t5/Discussions/Network-Outage/m-p/209791/highlight/true#... Are you able to call now?  If not, please try rebooting and try again.
Glennb2018
It's happening again. In Peterborough Ontario
srlawren
@soph thanks for confirming!
soph
 @srlawren
thanks for the reply, my phone is now working. 🙂
srlawren
@lxq1go @soph I just heard from the moderators that this was an outage and should be resolved now.  Could you please try again?  If still not working, try rebooting your phone and test again.
lxq1go
Same problem (still) , All topped up with $$$ and unable to make local calls, must be widespread, never have had a problem before!
soph
thanks so much
thapager
It’s speculation there’s an outage. No estimated time to repair as no one knows how to get in touch with PM technical. Check back often and check your phone’s outgoing calls regularly.
nexusfan
This issue is already open in atleast 2 forms...please read other forms
SnOop
seems wide spread.....bu tcontact the Mod Team to be certain...
