09-07-2021 02:51 PM - edited 01-06-2022 03:19 AM
my plan is expired few days a go. when I try to top up my balance it says that there is enough fund in your account. my payment history doesn't show anything and my number is not active.
Could you please help me with that?
09-07-2021 03:22 PM
@sjmycology See if you have any fund as Available Fund on My Account.
if not, then go to My Account->Payment Tab, One time Payment and and use Other to enter the amount manually, enter Plan Amount + $1 extra.
Once the payment gone through, check to confirm if "Reactivate Current Plan" button is there and click on it. Then logoff My Account and reboot your phone. you should be good from here.
09-07-2021 03:11 PM
This "glitch" seems to be coming up a bit recently. Try doing a manual top-up of $1 to ensure that the AutoPay function in your account is working (if set up). It seems that the extra $1 seems to help restart people's account as well.
You can always try to remove and re-add your credit card. This has come up a couple times so hopefully you'll be able ot get things going quickly. Let us know!
09-07-2021 02:52 PM
go sign in to Self-Serve, to review your account,
1. Click on Payment
2. Make a Payment
3. one Time Payment
4. you will see your Amount Due:$ !
5. Payment Type: selected other ( Enter the desired payment amount )
6. how much you see at Amount Due:$ ! you will do manually enter Amount: $ ! + $1 extra
what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
and if still not fix it follow this,
what is mean for Rebooting the phone means to turn off your phone about 2 minutes and turn it back on.
