password and email
hemjhaveri
My password and username is still now working after reset and it showed service error how can I activate my plan ?
2 REPLIES 2
cellphoneuser1
The site has been showing error messages the last couple of days. Did it say system error?  Keep trying until it works.
@hemjhaveri   so, you are still unable to login?
Try using Incognito mode to login with the latest password you reset and see if it works
If not, you might want to ask PM Support to reset it for you.  But again, using Incognito mode to login
1. For faster response (2-48 hours), use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or Private message to the CS Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
