09-14-2019 02:21 AM - edited 01-05-2022 08:54 AM
My phone is outgo calling 306-580-4001 (TELUS Mobility in SK?) automatically for time to time or my number is hijacked?, you peoples phone do same as well?
09-14-2019 01:09 PM
@ogojosan wrote:No I didn’t answer calls and I didn’t see voicemail icons, means they didn’t left messages?
The calls will be recorded as going to voicemail even if no message is left. Ignore this part of your usage summary.
09-14-2019 10:09 AM - edited 09-14-2019 10:09 AM
Could be a junk call. Maybe you blocked the call. Maybe the phone was out of range or not on or you were busy on it.
I get frequent junk calls that when I answer it a recording says "no one's able to take your call right now" and I scream back at the phone "then why'd you call me?!". So I block it. I'll then see that I "missed" a call.
You can also check your voicemail and see if anything's there.
09-14-2019 10:01 AM
09-14-2019 02:23 AM
@ogojosan wrote:My phone is outgo calling 306-580-4001 (TELUS Mobility in SK?) automatically for time to time or my number is hijacked?, you peoples phone do same as well?
This only means that an incoming call wasn't answered and that the call was directed to your voicemail.
