11-14-2019 10:00 PM - edited 01-05-2022 07:59 AM
Hiw come my phone not working in the us i have the international plain and cant get or make call or text.
11-15-2019 11:41 AM
@Kim1971kim wrote:Contact public mobile about that
@Kim1971kim why?
11-15-2019 12:57 AM
11-14-2019 11:49 PM
@grich2018 wrote:Hiw come my phone not working in the us i have the international plain and cant get or make call or text.
Do you have the $60 plan that was offered between July 19 and October 10 2019?
If yes, then your phone should work in both Canada and USA.
Otherwise with any other PM plan, you need to purchase a US Roaming add-on for your phone to work while in USA.
Which phone do you have? Have you tried restarting your phone?
Try connecting to AT&T or T-Mobile network?
11-14-2019 10:06 PM - edited 11-14-2019 10:07 PM
You need one of these add-ons, unless you have the $60 plan that includes US Roaming.
11-14-2019 10:03 PM - edited 11-14-2019 10:09 PM
Buying a US roaming add-on is the only way to use your phone in the US.
International calling as part of your plan means you can make international calls and texts WHILE IN CANADA only.
EDIT:
To buy a roaming add-on...
- log into your self-serve account
- click on the "Purchase Add-Ons" button
- choose the add-on you want, then add the funds to your account if needed
- go back to the add-ons page and select your add-on
