09-10-2020 06:18 AM - edited 01-05-2022 03:50 PM
i updated my iphone 8 and my sim card worked fine prior to update but now no service??? help??
09-10-2020 03:48 PM
I have tried these options, still no service
09-10-2020 02:39 PM - edited 09-10-2020 02:45 PM
go to Settings -> General -> About to check for a carrier settings update
remove your sim turn off your phone, clean the metal tabs if dirty. turn the phone on and reinstall the sim.
last option is to factory reset the phone. the software update may have corrupted the system. back up all your files if you decide to take this route
09-10-2020 02:11 PM
still no service
09-10-2020 07:43 AM
@joost Try running it through iTunes
1. Insert new working SIM - do not turn phone on (if SIM is already in, turn off)
2. Connect to computer with USB cable.
3. Start iTunes if it doesn't auto run
4. iPhone will switch on. Wait until iTunes registers it and checks for updates
5. Install the carrier profile update (if offered, if not, go to step 6)
6. Disconnect and restart. From @luddite.
If this fails try a network reset and restart your phone if it doesn't automatically do so.
HardReset.info:
APPLE iPhone 8.
