12-30-2017 01:28 PM - edited 01-05-2022 03:50 AM
12-30-2017 07:01 PM
12-30-2017 04:51 PM
Airplane on and off!
Ty
12-30-2017 04:37 PM
@fftljoe sorry to hear about your trouble.
Are you getting PM signal but no service or no signal at all?
Please try your sim in another unlocked phone or another Telus or koodo phone to see if you get service.
Or if the phone that you are using is unlocked, try someone else's sim in your phone to see if you get service.
Or try airplane mode on and off a couple of times.
12-30-2017 03:38 PM
Not a phone issue as far as I can tell ty though still out
12-30-2017 02:21 PM
Could it be a phone issue? Try using a different phone if possible.
12-30-2017 01:47 PM
Been a customer for a while now not renewal date I'm north of Toronto about 2 hours. Did reboot and sim pull
Still no service
12-30-2017 01:39 PM
Anything showing here: http://canadianoutages.com/status/telus/map/ ?
12-30-2017 01:33 PM
You need to help us help you with more information.
Are you a new customer? When did you sign up or port your number?
Is today your plan renewal date?
What phone are you using? Have you rebooted it?
Where are you located? Do other people around you that are with Telus, Bell or their subsidaries have the same problem?
