no route found
05-23-2023
10:42 PM
05-23-2023
11:21 PM
computergeek541
Someone tried calling my Public Mobile number from the USA but they received a "No Route Found" error
message. Is the error on their side (their service provider) or is this something in the Public Mobile set up?
Any ideas?
cheers
Service
05-24-2023 08:52 AM
Many thanks .....it is intermittent so that is likely the problem. Normally phone calls work fine so something is wrong with this service I guess
05-24-2023 08:34 AM
@George1509 - could be just a temporary network, technical, or capacity issue. Ask them to try again, or ask them to try a different phone number in Canada and see if the same happens.
05-23-2023 10:46 PM - edited 05-23-2023 10:47 PM
But you can receive calls from other without problem? And you didn't just join PM with porting, right?
It is likely a problem on the caller side. Ask them to reboot phone first and try again. Make sure they can call Canada and remember to put a 1 in front of your 10 digits number
