no network
12-30-2018 10:24 PM - edited 01-05-2022 02:55 AM
hello,
i bought a pbulic sim 2 days ago. My account shows active. I chosen and paid for the plan but there is no netwrok in my phone.I have tried all possible outcomes and searched on phone. I have trried resetting and changing the APN and preffered netwroks.Please kindly help me. I am not able to contact anyone from past 2 days.in desperate help.
Joining Public
12-31-2018 04:27 AM
@wetcoaster wrote:
@darcygibbs wrote:If you're having too much trouble trying to diagnose the issue yourself - I advise to just pop by one of the mobile botiques in your local shopping mall - Telus or the guys at WOW should be able to help you.
Personally, I set up my plan at The Mobile Shop inside Real Canadian Superstore and they were super helpful with everything including porting my number from Freedom and getting my 30 days free promo. Check in there if all else fails.
Please be aware that any of those options you mentioned are just selling / activating the phone plans. There is only one way to reach Public Mobile customer service for help with account related issues: through private message to the moderator team on this board.
https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/How-to-Get-Help/ta-p/251745
Hey there,
My belief is that the issues he's experiencing are more likely to be device related rather than related to his actual Public Mobile account. I think someone with more technical knowledge could help troubleshoot it in person.
-Darcy
12-31-2018 01:41 AM
i dont think its account related problem since my account says active, Maybe some error is thru their side.
But thanks for the help. Much appreciated
12-31-2018 01:33 AM
12-31-2018 01:29 AM
i tried using my friends phone,its still not qorking. it says sim not registered
12-31-2018 12:20 AM
12-31-2018 12:06 AM
12-30-2018 11:08 PM
i am not sure which preffered network to chose.Please help me in this
12-30-2018 11:05 PM
I tried to select various networks to see if its work. I dont knoq whats the probem. is it my sim or they didnt ctivate it
12-30-2018 11:04 PM
i did check on the site.So it does support 3g and 4 LTE
12-30-2018 10:59 PM - edited 12-30-2018 11:03 PM
have you checked out willmyphonework.net
i have a sneaky suspission that not all the bands are supported.
If it worked with oodo it will work with PM . have you tried selecting a different network?
12-30-2018 10:58 PM
i earlier had koodos and it was working
my phone is unlocked and its redme note 5 pro . it has compatiblity with public mobile
12-30-2018 10:56 PM
my phone was unlocked and i tried my sim on a friend's phone Samsung S9 still no networks
12-30-2018 10:54 PM
i have redmi note pro 5 and prefered network is TD-SCDMA/UMTS
12-30-2018 10:47 PM
Agree that you must first make sure the phone is able to work on any network. Was it working well on another network before you bought the public Mobile SIM card? Are you certain it's not blacklisted? Is it locked to a previous provider? What is the make and model of the phone?
12-30-2018 10:46 PM
@mimmo wrote:@Kp1003 lets strat with what phone you are you are using? what netwrork was it on before?
No offense, @mimmo.... But.... @Kp1003, how can this be the solution to your problem???
If you answer those questions we might be able to help sort it out. But there is not enough information in your initial post...
Here are a few of mine:
- Is your phone locked to your previous provider? (some brands, like Samsung, are known to lock their unlocked devices to the first SIM inserted, so just because it was sold unlocked a phone doesn't necessarily remain that way.)
- Have you tried the active SIM card in another unlocked phone?
12-30-2018 10:30 PM
