01-23-2026 08:08 PM
I just changed my plan today but after the change data is not working. SMS and call is working.
I'm using an eSIM. Please help as I need data. I've tried turning on/off airplane mode, restarting phone, resetting the network settings. using iPhone 15 pro
thanks in advance
01-27-2026 03:32 PM
I was able to get back the fee again and no further issues thanks
01-23-2026 10:30 PM - edited 01-23-2026 10:31 PM
hi @MLPM
happy that my suggestion helped
now, you just need to ask agent for getting the $5 back. Tell them what happened with the first sim and they will reimburse
Submit ticket using the way I mentioned above
01-23-2026 10:24 PM
So after buying a new eSIM I was finally able to get my data working instantly, not even a reboot was needed. It's a crazy that a simple plan change made data stop working on the plan. Anyways I was charged the $5 + tax ,Any agent here could help me get that refunded, I would appreacte it , thanks
01-23-2026 10:16 PM
hi @MLPM
you don't need to delete the old esim to buy a new one
but first, make sure you can receive 2FA and login to the app (this is what you need to buy new esim). if you cannot receive 2FA code via sms, click Didn't Receive code or Resend code and choose send email to get the code
if you can login, then go to Account page and click Purchase sim card and choose eSIM
01-23-2026 10:08 PM
was chatting with agent and ask me to tried again after turning phone off for a minute. He mentioned he did a system refresh and that everything look normal on their side, tried it and still no luck. Should I go ahead and delete my eSIM and purchase a new one? is that going to be refunded?, Agent is not responding anymore
01-23-2026 08:09 PM
HI @MLPM
look like you tried all the easy way. Some might suggest you to buy a new eSIM. But before going that way, I think you should ask PM agent to refresh the account first
submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
(If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit ticket by direct message:
