no cell service
mxzoom
not sure where to put this,  but i have no cell service this morning, can any moderater help please.
mxzoom
yes, this is resolved,   it was on my end , i have  a iphone5s and i ended having to back it up on itunes and do a complete factory reset, this resovled the searching, and i regained cell service and data.   thank you for all that helped.
srlawren
@mxzoom have you heard back from the @CS_Agent yet?  Were they able to resolve the issue?
mxzoom
i just contacted the mod. team ,   and yes my account is active , i am half way thru my 3 month term , and i rebooted the phone 3 times.  thank you .
will13am
@mxzoom, can you go into the self serve and check if your account is in active status?  Was there a payment due that was not fully paid?  If the account is active, try rebooting the phone.  Failing that, send a private message to the moderator team and have them investigate.  The moderator team can be reached via private message using this link.  Refer to the following link for information on contacting the moderator team.
http://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Updated-Contacting-our-Community-Modera...
