need help reactivating my sim
fash
im locked out of my sim and i cant make the payment the only option left is to leave public mobile
@fash
Do you need a PUK or are you locked out of your account?
dust2dust
The account pin is not required for entering vouchers.
But yes, an hour. And you can only make two attempts per hour.
Adding - sorry, I read the See more text and there was no period at the end so I replied. Then I saw the separate line after I replied.
HI @fash
please wait an hour to try again
Or you can go out and buy a voucher from Shoppers drug mart and load the voucher using *611
if you know the account PIN, you can also dial *611 and use the account PIN to make payment using credit card instead
If  you try again to login and still unable to , submit a ticket with cs agent
dust2dust
Buy a voucher online or in lots of stores and dial 611 to enter it. Are your services currently working?
