03-12-2023 04:47 PM
03-12-2023 06:34 PM
@diger - if you cannot find your post you believe you posted in the areas others are directing you too, perhaps it was bumped to the rejected pile. Check here for any rejected posts:
https://productioncommunity.publicmobile.ca/t5/premod/moderationitemspage/tab/rejected:forum
Don't feel offended if you find any posts here, may other members (including myself) have found misfit posts moved here for not particular reason it seems.
03-12-2023 05:08 PM
From here, @diger
About diger - Community (publicmobile.ca)
Choose the post you wish to amend, then tap the downward arrow from it to edit it.
It may also be in "draft" form, which you'll see on that link down a bit lower in the "Drafts" section (if there are any there...)
03-12-2023 04:50 PM - edited 03-12-2023 04:50 PM
Click on your community name and then you will see all your posts. Go to the one you want to change and click the downward icon and select edit post.
03-12-2023 04:50 PM
Click on on your username and you'll get to your thread starts. Click on the Replies and you'll get your replies.
Then open it and click on the little arrow to the upper right and click on edit reply.
