multiple phones/bills
myraivan
Hey Public!!!
My name is Myrl  Gamble andIi have purchased 3 cell phones over the course of months. Since I am paying all 3, I would like to consolidate all 3 phones under one bill (visa). What say you?
totalUser
Hi @myraivan
Unfortunately you can't make only one payment a month.
You should register them all under one card for autopay to collect rewards.
You could buy (once a month) 3 vouchers and login and apply them, but I think it's even more work than manually topping up.
I find it much easier to (once a month) just login in each account and make manual payment, I usually do it later at night when there is not too much traffic and site is not too slow, it takes less than 5 minutes
geopublic
@myraivan  Each phone requires a seperate account no exceptions. As others have already mentioned you can use the same credit card for all three by accessing selfserve for each account.
Triguy
You can add the same credit card to all three accounts.
To update or remove your credit or Visa debit card details, sign in to Self-Serve. Once signed in, click on the ‘Payment’ tab, then scroll to the bottom of the page and select ‘Manage my card’. Here, you will have the option to either select ‘Replace this card’, where you can enter the details for your new card, or ‘Remove this card’. You will need to review and confirm this change to your account and then you’re all set..Remember, accept credit cards (Visa, MasterCard, American Express) and Visa Debit cards that have been issued by Canadian or American financial institutions and are associated with addresses in Canada or the U.S. If you are using a payment card, leave the apartment/suite number in the payment information section blank.
popping
@myraivan wrote:
Hey Public!!!
You can enable autopay using your Visa card.
Select Payment tab from your overview page after login.
Select "Manage my card" link at the bottom left of the Payment page.
Add you Visa info and enable autopay.
gblackma
@myraivan you can use the same visa to pay for all 3 accounts. Just add it in your self service account to them. Stay safe.
