02-25-2020 10:42 PM - edited 01-05-2022 09:39 AM
Is moto e5 play compatible with PM? I can't find it on the list but I heard it might work.
02-26-2020 01:51 AM
@mikica It should work! If your concerned, or if it is convenient, you can also go to a kiosk/store and ask them to put in a test SIM. You don't want to find out that something may be wrong with the phone after activating, as there are no refunds for PM's prepaid services
02-25-2020 11:06 PM
no doubt it works, go ahead and activate a sim, through it in the moto and have fun 🙂
02-25-2020 10:56 PM
@mikica if it's the North American version it will work.
02-25-2020 10:47 PM
@mikica Your phone has this specification based on gsmarena website. Looks like it will work.
3G
bands HSDPA 850 / 900 / 1700(AWS) / 1900 / 2100 CDMA2000 1xEV-DO
4G
bands LTE band 1(2100), 2(1900), 3(1800), 4(1700/2100), 5(850), 7(2600), 8(900), 12(700), 13(700), 14(700), 17(700), 25(1900), 26(850), 29(700), 30(2300), 38(2600), 41(2500), 66(1700/2100), 71(600)
Needed frequencies:
3G
850MHz, 1900MHz
4G LTE
Band5-850MHz, Band4-AWS, Band2-1900MHz, Band7-2600MHz
02-25-2020 10:47 PM
@mikica , you could try a reverse lookup. Use the following band information and determine whether your phone has these bands.
02-25-2020 10:44 PM
@mikica wrote:Is moto e5 play compatible with PM? I can't find it on the list but I heard it might work.
There are multiple variants wordlwide for many models of cell phones. The Canadian version will work for sure and is sold by some Canadian carriers.
