03-20-2020 10:21 AM - edited 01-05-2022 10:00 AM
I am new customer, so far i have not been able to connect to Mobile Data,
03-20-2020 10:29 AM
Try network reset too, sometimes that does the trick
03-20-2020 10:24 AM
What make/model/submodel is the phone for compatibility?
Also, find your phone on this list:
Officially Recognized APN Reference
If your phone isn't there maybe these might work:
APN Settings:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN type: default,mms,agps,supl,fota,hipri,dun
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
