mobile data
ElenaAssa
How to check the rest of my mobile data
2 REPLIES 2
Sansan
To check my data information,  I use only the website so on the Overview page. I click on Usage Breakdown and it's show right there in the middle of the screen how much is the total,  how much I use and the remaining amount.
@ElenaAssa
Login My Account or the App and you can check the how much data you used and how much left.  it is on the Overview page after you login.  Or you can call *611 for the info as well
