long distance
bearskim
I made a long distance phone call inside my province and was alerted I may have long distance charges? Canada wide calling on my plan should cover this? Also can I text Canada wide as well. Thanks
 @hairbag1
Just to be clear on the definition of from above...while in Canada.  🙂
You can send / receive texts from anywhere on the planet...not just Canada.
EDIT...yes...assuming you're in Canada, you can send / receive texts from anywhere.
Thanks @Anonymous
popping
Dial 1 in front of your phone number will get rid of the warning message.
Text message is always Canada wide.
PM is prepaid service and does not have pay-per-use charge.  Therefore, if PM connects your call, there is no extra charge.
JoyLuck
@bearskim wrote:
I made a long distance phone call inside m y province and was alerted I may have long distance charges? Canada wide calling on my plan should cover this? Also can I text Canada wide as well. Thanks
All current plans have unlimited texting. There are no long distance charges. Try putting  a 1 in front of the number.
hairbag1
Just ignore that message...you'll never be billed later.
With PM if you don't prepay for something...you won't be billed later.
RossN
@bearskim hi yes you can you won't be charged just use a 1 before your number you are calling
