incorrect email for account
Jackson
Hi,
I inadvertently made an error in the email address I provided when I set-up the account.  How do I change email address?  Thanks.
CalgaryBen
@Jackson wrote:
Hi,
Are you able to log into your self-serve account using the incorrect e-mail as your username, @Jackson?
If so, this post is apropos.
Alex888
Log into "My Account" select "Change Username" enter in the new email as the new username. It says that it will not change the email address in your profile but it should.
popping
@Jackson wrote:
Hi,
Send a private message to moderator for help.
