04-30-2018 04:33 PM - edited 01-04-2022 04:12 PM
@CS_Agent can anyone help with an incomplete number/account porting from Virgin?
I can send/receive texts, and phone out but any incoming calls are going to my old phone/sim card.
05-08-2018 01:03 AM
thanks for the link. I'll contact the moderators. It's been two weeks and still hasn't ported through properly.
05-08-2018 12:51 AM
oops. double post was a mistake, as didn't see the first post go out so thought it hadn't worked. sorry about that.
04-30-2018 05:27 PM
@will13am maybe merge the two threads?
@ryanelden FYI:
How long until a moderator will reply to my private message?:
How can I view my private messages between myself and a Community Moderator?
04-30-2018 04:42 PM
@ryanelden, duplicate posts are not going to help speed up the process one bit. If you have waited some time for the port and have messaged the moderator team because of a stuck port, the only thing you can do is sit back and wait. No point in getting anxious over something that you no longer have control over.
04-30-2018 04:35 PM - edited 04-30-2018 04:38 PM
You have posted this already in a previous topic.
Port-ins can take anywhere from 5 min to 24 hours if you are porting in a number from another wireless provider. I can't speak to specifics for Virgin.
Here is what you can do if you think it is hung up and needs intervention:
Please contact the moderator team to look into the incomplete port. The moderator team can be reached via private message using this link. Refer to the following knowledge base link for information on contacting the moderator team.
Copied this answer from the other topic.
