06-10-2020 03:35 PM - edited 01-05-2022 12:10 PM
i have the $50 8gb data plan and everytime i try to send an imessage it doesn’t go through and makes me send it as SMS? Help please! 🙂
06-10-2020 04:04 PM - edited 06-10-2020 04:06 PM
@SilasXavier wrote:imessage is turned on, but when i’m out and about and trying to send an imessage it makes me send an sms instead, but when i’m on wifi it works perfectly fine? weird.
Optimum setup: Settings >> Messages >> iMessage ON, Send as SMS ON, MMS ON >> Send & Receive: should show your phone number and Apple email.
Check your account to see if there is a block of data showing under Data & Add-ons; none showing means you've used up your data allowance.
06-10-2020 03:54 PM
06-10-2020 03:49 PM
@SilasXavier hi do you have imessage turned on in your settings?
06-10-2020 03:49 PM - edited 06-10-2020 03:50 PM
Trt these 2 things in order @SilasXavier .
Stay safe
