07-04-2018 11:31 PM - edited 01-05-2022 05:02 AM
Just arrived back from USA to Toronto & my pic text always doesn't work when I get back. Can someone please help
07-09-2018 06:37 PM
I hit reset & somehow it worked. Thanks for replying
07-05-2018 12:02 AM
@Jeng2 you can go to this website by your phone web browser to install APN http://www.unlockit.co.nz/unlockit/ if you have a phone with Telus/Koodo you can try to reset network settings.
07-04-2018 11:50 PM
@Jeng2 wrote:This happens all the time & used to be able to call speak with support and they would tell me what to type
Please follow this knowledge base post.
07-04-2018 11:43 PM
07-04-2018 11:41 PM
What should the APN set as?
07-04-2018 11:39 PM - edited 07-04-2018 11:40 PM
Check your APN settings. It might still be connected to one of the US carrier. If you receive other texts, your service is probably working fine.
