Tuesday
My phone has had no network and stuck on SOS all day. Tried rebooting my phone, tried toggling airplane mode on and off, tried resetting my network services. I changed my SIM card to another Iphone and doesn't work either. None of these worked. Please help asap.
Tuesday
Hi Lisa, same thing here, since yesterday!
Tuesday
are you in :
Simply open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA code when login, use email to receive code instead of SMS if you cannot receive the text on the phone.) When open Chatbot ticket, Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble using Chatbot to open ticket, then message PM using this link:
PM will reply to your community inbox, between 9AM-10PM EST (Mon-Sun), check here:
Tuesday
Thanks for reply.
My account is in good standing, but my location as Cable Damage issue from 12:00AM @apr 28 2026.
Could you tell me when it will be fixed? as i really need my cell phone works asap.
Thank you,
lisa999
Tuesday
look like it is an account issue, did you check if your My Account is showing active? maybe there was issue with plan renewal?
If the account is active, check if any confirm local outage. There are some active outage now:
https://www.telus.com/outages
if all good and you cannot find the reason, ask PM CS agent to check. Please private message CS Agent at:
