iPhone SE Compatibility
Snowkoyuki
I bought an iPhone SE recently from the Apple store and it seems to be unlocked. It says there is no SIM lock. Currently using it on Koodo network. Will it be compatible with the public mobile network? Planning to get both data and calling/text plan.
Thanks in advance!
@Snowkoyuki
Yes your phone is fully compatible with public mobile. Be sure to check in to the community regularily for the announcement of the next flash sale so you can register your email for the promotion (usually a free third month credit.) As mentioned by @Anonymous if you need a referral code just make a new friend by private messaging a member and ask for their referral code. They will happily oblige.
Read this post on how to stack promos with the bundles offer by CCS....
https://productioncommunity.publicmobile.ca/t5/Announcements/FLASH-SALE-Get-one-month-of-service-for...
BCW
I have a iphone SE and moved to PM last month without any problems.
HALIMACS
@Snowkoyuki
Not only will virtually ALL iPhones work here, but if a device is functioning on Koodo, it'll work on Public Mobile.
TELUS is the 1st tier provider, with Koodo being it's 2nd tier, and Public Mobile it's 3rd tier.
They're all part of TELUS Corporation.
Staliger
@Snowkoyuki Yes, since the phone is unlocked, this model will work with PM without any issues. Go for it😉
 @Snowkoyuki : Yes.
Don't forget to use a referral code during activation to get a $10 credit. People sending you codes in your private messaging un-asked for are violating the rules of the place. You can ask here or ask a user.
Yes is will working 100%
for public mobile phone compatibility
you have to put it a device brand for any phone to you can see all information,
you can visit here >>
WillMyPhoneWork.net - Check if your phone works on a network
following  >> To find out if your cellular phone is compatible with our network, click  HERE
visit Here  to you can full information about your device.
Good Luck
