iPhone 6s "no service" almost every hour or two
06-12-2018 03:38 PM - edited 01-04-2022 06:10 PM
Hi,
Since going from an iPhone SE to an iPhone 6s, the carrier signal seems to drop every couple of hours, sometimes every hour.
I tried all the basic things like using 11.4 iOS, resetting network settings, removing/replacing sim card, restarting phone, etc. It keeps doing it.
Please help. Thank you.
Phones
06-19-2018 08:54 PM
06-19-2018 08:11 PM
If @darjman's suggestion of exchanging the phone where you bought it doesn't work out, trying a new SIM card couldn't hurt... at least that's what I'd think. I'm wondering if this has to do with some water damage on the SIM card contacts? I've seen contacts get some green calcification on them. Hopefully you didn't buy the phone off Kijiji and now the person is gone.
@ute1978 I'm curious... did you ever figure out why your phone would drop its signal when your husband called you? how did you fix it?
06-19-2018 07:19 PM
If it's a brand new phone, I would suggest returning it and just buy another one. It seems to be an issue with the phone, in my opinion.
Also, not sure if you are aware, but the SE is the exact same as the 6s, in terms of its internals. The only difference is the size of the phone, so maybe you could get a different phone or just use the SE?
Not sure what your situation is, but just a suggestion. If you're happy with the 6S, power to you.
06-13-2018 12:36 PM
Could this be because my SIM from PM is quite old and although it was working with my old SE, its not doing so well with the 6s?
It's still dropping signal every 10 minutes when i'm out and about. I see it go from 4 bars, to 3 bars, to 2, to 1 and then no service.
06-12-2018 10:44 PM
@AKwan wrote:Yep, many times. Apple store just replaced my battery today and looked at the phone. They don't see any obvious damage to the antenna, but after replacing the battery, it's still dropping signal regularly. 😞
I have written a few times in this community about my similar problem with my 5s.
All day long I have full bars reception on my phone. The moment my husband calls me all bars disappear and the service changes to "no service". I lose the call.... This lasts about 5 seconds and then all bars and service is back.
06-12-2018 07:58 PM
06-12-2018 07:57 PM
Doing that currently. 🙂
06-12-2018 07:56 PM
Is there a way to force a carrier update?
06-12-2018 07:56 PM
I tend to agree.
06-12-2018 07:56 PM
Unfortunately, it's not a new 6s and the sim works fine w/my old iPhone SE. 😞
06-12-2018 05:54 PM
Tried re-seating your SIM card?
06-12-2018 03:56 PM
@AKwan You can also try to restore your phone via iTunes to see if it’s better
06-12-2018 03:54 PM
You can try a carrier update:
- Make sure your device is connected to a Wi-Fi or cellular network.
- Tap Settings > General > About. If an update is available, you'll see an option to update your carrier settings.
06-12-2018 03:43 PM
If the sim works fine on other phones, it seems like there is some issue with your iPhone 6s.
06-12-2018 03:41 PM - edited 06-12-2018 03:42 PM
@AKwan So there’s something wrong with your phone hardware. Maybe sim card slot doesnt work consistency & signal chip inside your phone. Did you purchase a brand new iPhone 6S?
