Nothing is working
Felix12312
Hello, so i just recently switched over from koodo to public mobile and after about a day of waiting, i was sad to see that nothing is working. No data, cant call or text, cant transfer my koodo nunber over. ive tried every solution i can on the forums, but none seem to work. Pls help
hung52
Easy way is to Contact a Mod.
You must include your:
email address,
Simcard #,
Porting number,
Old account #,
your full address and your full name.
Koodo and PM share the same network so phone comptability should be causing this issue.
Ahmedlatifi
have you tried restarting your phone, or putting the sim into different phone, sometimes phones are not compatible to CDMA, try checking your phones compatibility over here: https://publicmobile.ca/en/on/get-started
nishufan
Hi @Felix12312
   Sent private message to our moderators with you kodoo account number and your phone number. They will help you asap. Thanks
dubcanada
Have you sent a message to the moderators?
