04-20-2020 10:54 AM - edited 01-05-2022 10:27 AM
Is the iPhone 11 Pro Max compatible to the Public Mobile platform? If there are issues, what are they? Can the SIM card currently in a iPhone 7Plus be transfered seamlessly to the iPhone Pro Max?
Joining Public
04-20-2020 01:39 PM
Hello@Emmanueljnr022
That's correct both Iphone 7 Plus and Iphone 11 Pro Max are using nano sim card and both phones are compatible with Public Mobile platform.
Lucian PM Mod
04-20-2020 01:32 PM
Yes the sim card from your Iphone 7, can fit into Iphone 11.
04-20-2020 11:53 AM
@lolaww724 Most of modern phones, including IPhones, support PM, so don't worry and enjoy the device with our service!
04-20-2020 11:39 AM
iphones use nano sim cards i had an older iphone 5s and that used nano.
04-20-2020 11:21 AM
Will do. Thank you!
04-20-2020 11:21 AM
Both phones should be using nano sims.
04-20-2020 11:20 AM - edited 04-20-2020 11:21 AM
@lolaww724 wrote:Hello!
How do I know if I have a 'Modern SIM'? My SIM from PM was purchased in 2016.
gsmarena says both your phones are nano-sim. Don't worry about it. Forget I brought it up. 🙂
04-20-2020 11:15 AM
Hello!
04-20-2020 11:06 AM - edited 04-20-2020 11:24 AM
As long as your new phone is unlocked and both phones use the same size sim usually nano sim then it should be easy to switch over the sim.
04-20-2020 11:01 AM
@lolaww724 wrote:Is the iPhone 11 Pro Max compatible to the Public Mobile platform? If there are issues, what are they? Can the SIM card currently in a iPhone 7Plus be transfered seamlessly to the iPhone Pro Max?
Modern SIM's come in 3 sizes that can be punched out of each other. If the size needs to be different between phones then you can punch out to smaller and carefully snap back to go larger with the original parts. (if you kept them)
04-20-2020 10:58 AM - edited 04-20-2020 11:00 AM
@lolaww724 It s 100% compatible with PM According to https://apn-canada.gishan.net/en/apn/public-mobile/apple-iphone-11-pro-max
It has all the required 3g and 4g LTE bands. And switching your SIM card should result in a seamless transition. Just make sure its unlocked. Stay safe.
