11-23-2017 11:56 PM - edited 01-04-2022 03:00 PM
My wife and I both have iPhones (an iPhone X and an iPhone 7 Plus) with Public mobile accounts. No changes have been made to our settings but on Tuesday our texts started sending (green instead of blue) as text messages instead of iMessages. All other texts to non Public mobile iPhones still go through as iMessages.
Rep at the Apple store looked at the phones... played/looked at the settings... shut off iMessage and FaceTime...rebooted...sent a few texts and told us that the issue was with my provider.
Just wondering if this is a known issue or is it an issue with the network and my new iPhone that will require a network update?
thnx
12-15-2020 07:28 PM - edited 12-15-2020 07:30 PM
Yeah thanks. Interestingly the phone prompts me to turn on cell data when I attempt to switch on 'iMessage' (photo 2), but as you can see by the LTE icon it is already on.
12-15-2020 07:16 PM
@masondking wrote:I can't send or receive iMessages with a number recently ported into Public Mobile sounds similar. What was the actual fix to this issue?
Hi @masondking
Ensure your:
- data is enabled
- SMS is enabled
- MMS is enabled
12-15-2020 07:12 PM
11-24-2017 01:24 PM
So happy we could help 🙂 Glad everything’s good now.
11-24-2017 01:21 PM
Again thanks, pretty amazing that Public mobile has tech support @Rockdaddy22 @srlawren available at 1:00 in the morning pst (4:00am EST)
@Rockdaddy22 was nice enough to run a test last night with his phone and it worked, but was still not working on my Public/Telus contacts. I was ready to get up this morning and go to , but for some unknown reason (no updates or setting changes...or even tinkering this morning) iMessage is working this morning on both phones with all Public/Telus contacts.
First world problem fixed(?) ... this community is amazing
11-24-2017 12:11 PM
At least we had it working with 2 public Mobile iPhones 📱
11-24-2017 11:42 AM
@Rockdaddy22 well, some progress anyway eh? Thanks for the updates!
11-24-2017 11:42 AM
Not sure if it’s working with the iPhone in question, but when we tested last night it worked.
11-24-2017 11:41 AM
Great! So is this resolved now?
11-24-2017 11:41 AM
Test was successful 🙂
11-24-2017 11:39 AM
@Rockdaddy22 @BCrtr did you guys get to test?
11-24-2017 03:44 AM
Can I send you a test tonight? If so send me you number in a private message.
11-24-2017 03:41 AM
Thnx guys,
We both have over 10Gb’s left in our accounts, and still over a month to go on our 90 day plans. Data is working... Apps are working...Imessages are working just not to Public/Telus contacts (tried with two contacts on Public and one on Telus). As suggested, when I turned off “send as SMS”... it still sends as text and the same if I switch to my ID instead of my number. Great ideas... I’ll give Apple a call tomorrow now that I know it’s working for you.
again thnx
11-24-2017 03:07 AM
You also have 90 days of free telephone support with , don’t be shy about using it. Maybe they could get you more technical help on the phone than in store.
11-24-2017 03:05 AM
I’m using the iPhone X and my girlfriend the 7 Plus. We’re definitely not experiencing these issues on my Public Mobile.
What happens if you turn off (send as sms) in settings under messages? Also what if you send it to the ID associated with the phone instead of the phone number?
11-24-2017 02:54 AM
@BCrtr just a theory here: could one or both of your accounts have run out of data? Are both phones able to browse the web and use other data-consuming apps?
Other than that, I'll defer to my favourite iPhone experts @Luddite and @Rockdaddy22
