i cant process payment
aaronlmm
Hi @Patrick1188 first wait an hours and test again.
if you need agent to help, submit ticket
at : https://publicmobile.ca/chatbot.
First type Forgot Login,
Patrick1188
Same here. Cannot process payment because of credit card replacement. Tired two different active cards without luck. The only error message is "Oops! Something went wrong, please try again later.". Ended up buying the voucher from Canadian Tier gas station. It's not like the gift card. You will have to ask the cashier. Just a voucher code that was printed out by the cashier.
@aaronlmm
How are you processing your payment?
Online on your account?
Or by *611?
HALIMACS
Worst case @aaronlmm , get a payment voucher from many mobile and drugstore locations, shoppers drug mart, or shell.
Use 611 to apply it, or self serve site.
Stores with payment vouchers:
https://publicmobile.ca/en/on/payment-voucher
HI @aaronlmm
if you tried more than twice, it is better to wait an hour before trying again
Next time when you try, try only once but using Incognito/Private/Secret browser mode
if that does not work, try *611  and pay there, but make sure you have your 4 digits PIN
