how/where do I get a Pin ?
jfedderson
2 REPLIES 2
@jfedderson
You create the secret PIN when you activated your SIM so only you will know.
You can similarly change the PIN as per @Outdoorsman recommendation.
Outdoorsman
@jfedderson hi just sign into your self serve account go to profile , you can change or create a new pin there
