08-26-2022 08:07 PM
I only have 5gb data per month. Just use for the new and send email, no music and video. still need 300mb everyday. Want to know how to save it. thanks,
08-27-2022 10:55 AM
1. Don’t expect that your data won’t be working when you are using wifi
2. Leave your data off and only turn it on when needed
3. Don’t allow any refreshes or updates of apps or operating systems while using data
4. Switch off any apps that you don’t want to let them operate while using data.
I never use all my 250MB.
08-27-2022 06:45 AM
Here is some more tips on data usage that can help you conserve data usage and/or find where high data usage is coming from.....
*Android and iPhone's data saver tools work differently it is prudent to check settings in each phone's apps for such things as your photo app for device syncing, backing up etc.... Note: viewing or searching for backed up/stored photos can use considerable mobile data.
**Public Mobile sends out a text from 611 giving a warning at 75% and 95% of total data usage. If you have data add ons these warnings include both plan data and add on data.
**So if you just have 1gb of plan data you will get a warning at 756mb/1024mb and 973mb/1024mb. However if you have 1gb of plan data and a 5gb data add on (1024mb+5120mb=6144mb) these warnings will recieved at 4608mb/6144mb and 5837mb/6144mb respectively.
**This is why setting your data warning and limiter is important so that an errant app's sudden usage can be noticed and/or stopped by your phone's data usage tools rather than relying on pm's limited warnings system.
***Background data can use up to 38% of your data that is pure wastage.
Get in the habit of taking screenshots of your overview page and payment history before and after renewal for record keeping and checking that your data and/or limited minute/text counter resets.
08-26-2022 08:56 PM
you use higher data amount, so why not to change plan to $55/ 20 GB/ Data at 4G speed for LIMITED TIME.
08-26-2022 08:53 PM - edited 08-26-2022 08:54 PM
@Jason998 If you are a light data use who needs data for basic stuff like news, browsing and emails, 5GB data a month is still a lot. I am a very low data user and manage most of the usage over WiFi. If you're on Android, use DNS services like NextDNS to block ads or use Kiwi browser that comes with built-in ad-blocker. All those ads failing to load will overall save some data. Other than that, go through your apps like Whatsapp or Twitter and see if they are set to auto download images/videos over data connection. Turn that off and stick to manual download.
08-26-2022 08:43 PM
If you think you're such a light data user, why are you on a 5gb plan? You could also set the settings to not allow updates of the OS or apps over cellular/mobile data. Wifi only.
08-26-2022 08:36 PM
turn off all app background.. and Resolution/Quality Video fix it to 720p HD, or lower.
if possible more connect to Wi-Fi.
08-26-2022 08:12 PM
@Jason998 Hi I have no idea what your habits are but turn off Wi-Fi assist use Wi-Fi whenever you can turn off data when you’re not using it
08-26-2022 08:11 PM
@Jason998 , can you check the data usage on each of the app installed on the phone. That is a pretty healthy amount of data usage. Some kind of app is doing a lot of stuff in the background.
