how do i port from koodo
fhvivb
I have created an account with a new number.  How do I now port my Koodo number?
PAULRANG18
Self serve will make it easy to port your number. Make sure to register for self serve first.
fhvivb
Thanks I will send a message to moderators
GinYVR
@fhvivbIf you are Koodo postpaid you can use selfserve to port your number.
If you are a prepaid customer you need to contact the moderators.
Porting number to Public MobilePorting number to Public Mobile
