free call between 2 lines?
dcmlfrog
Hi, I am considering transfer my two lines to freedom mobile but I do have one more question regarding the plan cost.
With my current carrier, the phone calls between two lines that both with my current carrier are free. It is the same for Public mobile or not?
Thx
8 REPLIES 8
@dcmlfrog check your inbox here if you need a refferal code!  Also after you set up your first account use that refferal code to set up your second account!  Good luck
sunflowershine
@dcmlfrog Please let me know if you need my code.
You won't get a deduction right away. But you will have a $10 reward to be used after the first month.
@dcmlfrog wrote:
Thx everyone. Is a referral code required for swtiching the PM? Would be that of particular benifit? I don't mind add one if that helps someone to get some price cut though.
Thx
Referral code is not required, but you will get $10 credit if you use it and other party gets $1 off + the bonus $20 as a promo.
dcmlfrog
Thx
@dcmlfrog  also now is the time to switch with the black Friday 5gb bonus data and the friend refferal bonus. You need a refferal code for your first account but then you can use your first account code for your second account!
@dcmlfrog  Unless you choose the $15 plan all plans come with unlimited Canada wide calling. The $15 has free texting, free incoming calling and 100min outgoing. A $5/500min add on can be purchased for insurance and it rolls over each month til used. Very economical if you don't need to call out much . And the add on at $0.01 a minute is a no brainer.
@dcmlfrog  but if you're on the 25$plan or higher its unlimited calling anytime and anywhere in Canada
sunflowershine
@dcmlfrog No. PM won't have that policy.
