02-28-2024 12:04 PM
l am just wondering if there is a way to talk to a public mobile mobile agent as l am trying to transfer to public mobile and it is telling me l am getting we are having transfer my number as i enter a wrong esn/meid number and l enter my imei number and the number i want to port and how can l fix that
02-28-2024 12:44 PM - edited 02-28-2024 12:46 PM
Private Message customer service directly, this link will create the message....
Watch your Community Inbox - Envelope at top right beside your Avatar
Reply to CS_Agent in Community Inbox
Replies from CS_Agent may get CC'd to your Email but you cannot reply there.
02-28-2024 12:22 PM
ok i have reply to it
02-28-2024 12:16 PM
i did but it is telling me i provide the wrong esn/meid number
02-28-2024 12:10 PM - edited 02-28-2024 12:17 PM
Use Account # from your previous provider - I found that works every time!
Not sure if you can change that - I also had issues with transferring using IMEI because you need to supply the IMEI you set up with your previous provider when you set up your account....
