03-18-2023 07:58 PM
03-19-2023 12:24 AM
That is good news.
Did you use the suggestion provided by @softech (first reply to your asking for help) to create a support ticket?
If yes, wait for a reply from a CS Agent who is PM employee. CS Agent will ask you more question to get you back on your account. Watch for your private message inbox(The envelop icon at the top right corner of this page) from the CS Agent.
Ask if you have more question.
03-18-2023 10:57 PM
the verification code was sent via SMS from PM
03-18-2023 10:54 PM
@Obadiah4 wrote:yes, i got a verification code today
I am confused. How were you received a verification code if you cannot access to your email or SMS message?
03-18-2023 10:51 PM
03-18-2023 10:49 PM
Only a CS_Agent can help you change your email address and to access your account once credentials are confirmed Eg. your security PIN.
03-18-2023 10:45 PM
nothing comes up for me to follow your instructions
03-18-2023 10:41 PM
@Obadiah4 wrote:[email protected] was made for me by the customer rep when i activated my number. i do not thing this is a real email issuer
Do you still have access to your PM SIM card to received SMS text message to verify your identity?
03-18-2023 10:28 PM - edited 03-18-2023 10:28 PM
Don’t know how to account your email address?
Clear cache and go incognito on your browser then click on Forgot Password.
03-18-2023
10:25 PM
03-18-2023
11:19 PM
NDesai
03-18-2023
09:59 PM
03-18-2023
11:39 PM
computergeek541
@Obadiah4 wrote:i can login but its asking me to verify and i do not know how to access this email(xxxxxxxxxxxxx) to verify my account
Do you own the email in question when you activated your PM account?
If yes, you need to re-gain control your email address from the email issuer of your email.
There is nothing PM can do for you as PM. The email registered on your account is the only proof that PM can use to ensure that you are the owner of your account.
03-18-2023 08:46 PM
that is why i want to change my email so i can access and verify to be about to login
03-18-2023 08:44 PM - last edited on 03-18-2023 08:51 PM by CS_Agent
i can login but its asking me to verify and i do not know how to access this email([email protected]) to verify my account
03-18-2023 08:26 PM
@Obadiah4 them open ticket with PM support as advised above for PM support to update it to an email you have access
03-18-2023
08:21 PM
03-18-2023
11:38 PM
computergeek541
this is my email xxxxxxxxxxxxxx and they are asking me to verify and i don't know how to access this email
03-18-2023 08:05 PM
What do you mean by reset? Did you try the reset password function?
03-18-2023 08:04 PM
@Obadiah4 reset email as in just password reset or change email address?
if password reset , first try to use the Reset Password link there on the login page (or direct link: https://myaccount.publicmobile.ca/en/forgot-password) enter any possible email addresses you could have used and see if it works
if that does not work or you need to change email address, PM support will be your friend then, please open ticket with them
1. Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
