eSim not installed
Dolly45
I've been having issues with getting it downloaded. How do I request to use a Sim card ?
1 REPLY 1
@Dolly45  You can buy physical SIM card from Telus Koodo store or order from amazon . Once you have sim card in hand in your account profile page you can sim swap the number
SIM  SWAPPING  profile tabs
Of you can log into your account ask support to siI’m swap the number for you
submit ticket with support . using the chat bubble bottom right of screen
If that doesn’t work you can always send private message to support .
send  a  private message   To CS_Agents
