eSim QR code
Fer997
How can I get a eSim QR code instead of having to install the app and make it install the eSIm on thaty device?
1 REPLY 1
HALIMACS
Regrettably, you do need the Public Mobile app to activate here @Fer997
If you don’t want to do it on the device being used, you’ll need to borrow a device that can download and utilize the app.
After your set up, you can always use the web-based site for account access.
