01-14-2026 05:46 PM
I just activated a public mobile account, I haven’t received my eSIM email. What is the next steps. Activation process stuck.
02-18-2026 11:51 AM
On iPhone: check Settings > Celluar and see if the eSIM is there. If it is, make sure the PM eSIM is set as Primary on "Cellular Plan Label" and "Turn on This Line" is toggled on
01-14-2026 06:21 PM - edited 01-14-2026 06:22 PM
to contact pm, open ticket
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
01-14-2026 06:03 PM
How do I contact customer service in order for me to receive the activation email with the eSIM QRcode
01-14-2026 05:58 PM
I don’t see the option you stated. How would I go about downloading the eSIM in order for my service I just activated to work ?
01-14-2026 05:49 PM
did you use the Public Mobile app to activate and reach Step 6? If you did, you don't need the QR code, the app already installed the eSIM for you. Check the Sim Manager and you should see Public Mobile eSIM there. Just make sure it is enabled and set as Primary and Reset network settings once and it will work
