09-20-2025
10:03 AM
09-21-2025
01:54 AM
computergeek541
I am getting a new iPhone and it only takes a eSIM I have never had one before how hard is it to get it on my iPhone
4 weeks ago
it’s like come, nothing happened because in physical Sim, you have to open the tree and then place the Sim card plastic piece in the drain and insert then you have to configure in the setting, but in case of eSIM you go to purchase section and buy eSIM and then you got a option install eSIM now justclick yes and boom five seconds after you will know that USM is working and installed on your device and you can by going into device settings cellular option. Ok now bye takecare brother.
09-20-2025 01:17 PM
09-20-2025 10:14 AM
@car62 wrote:I am getting a new iPhone and it only takes a eSIM I have never had one before how hard is it to get it on my iPhone
Hey @car62
It's pretty easy actually. Just download the app, sign in, go to purchase SIM and pick eSIM and follow the very simple instructions. I've done it and it took under 5 minutes.
