eSIM
Paydn
My eSIM keeps failing to install and when I go to login for help nothing comes up for me to login and ask questions.
1 REPLY 1
hi @Paydn do, the Settings -> Cellular or Sim Manager screen does not have the PM eSIM?
you can message PM support agent for help
you can  submit by direct message:
