01-27-2026 04:04 PM
I changed provider to Public, eSIM not working, submitted ticket to get new eSIM sent to email. Been 2 days, nothing yet.
01-30-2026 09:26 AM
@Thuc We apologize for the delay, as we are facing a high level of cases, our response are taking more than expected, but please, review your community inbox, as I can see that one of our team members responded since yesterday.
01-27-2026 08:23 PM
Hey did you also get the "eSIM not installed" error? I had that and able to get it working now by purchasing a new eSIM on the app.
01-27-2026 06:25 PM
Without phone for 48 hours, sent 4 tickets, CSAgemt is not responding.
01-27-2026 04:06 PM
hi @Thuc
can you double check if the PM eSIM is already showing up on your Sim Manager or Settings-> Cellular?
if yes, then you need to manually enable it and set it as Primary (please also remove old carrier sim card and disable old carrier esim)
but if it is not there you will need to ask PM support agent to help, you can submit ticket by direct message:
